Mexican 1600i fuel pump
Bruce.m
Post by Bruce.m »
Couple of reference photos.
This one is a Chinese copy.
Bruce.m
Re: Mexican 1600i fuel pump
Post by Bruce.m »
Bruce.m
Post by Bruce.m »
Top has 3 connectors (8mm), lowest is feed from tank (via 8mm outlet), top is the vent to tank top, middle is return from pressure regulator. Also output in the top from pump.
Inside the pump is a Golf mk2. 114ltr/hr at 3 bar. Good for 100bhp or so. Pump has a mesh screen around it.
Two halves are sealed by large o-ring.
Pump design enables the use of a stock carb tank with no baffles.
Paul H
Post by Paul H »
Pump looks interesting and probably it's quiet . I bet it will flow more than 100hp
Bruce.m
Post by Bruce.m »
The white baffle (for input/ return to pass through) with mesh filter appears to be removable but I didn’t go that far.
Pump might be bonded in at the top although I was hoping it would use an O-ring, in case I needed to swap out the pump for a higher flow rate item.
For the price, I thought it was worth a look.
Paul H
Post by Paul H »
I just ordered one $35 . I'll put it on my flow bench and see what it will do through a 3 bar filter/reg
Bruce.m
Post by Bruce.m »
Great, please share the info when you have done the testing, if you don’t mind.
I have a basic 1641 built & making low cost EFI for it next (including using this pump).
Paul H
Post by Paul H »
Yes will do It'll be ideal for the bus conversions I make which are sub 150hp and mostly sub 120hp
Do you have the electrical connector part number ? It looks like a standard but you never know
Bruce.m
Post by Bruce.m »
Standard golf connector I think.
Bruce.m
Post by Bruce.m »
Guessing the original part number is VW 191906232A but it should be a generic connector.
Paul H
Post by Paul H »
Pump arrived so I might even get to test in the next few days as I have the flow bench out ready.
Connector is larger than I thought and I can't seem to find them anywhere at the moment
R2.0
Post by R2.0 »
Tagging for test results. It would be nice if it supported more HP.
1972 Karmann Ghia Convertible
"As God is my witness I though turkeys could fly." - A. Carlson -
Bruce.m
Post by Bruce.m »
Paul H wrote:Pump arrived so I might even get to test in the next few days as I have the flow bench out ready.
Yes, it like a large JPT socket. Probably made by Tyco / TE . The plug is obtainable from VW Classic (you get the pins separately). I was going to see if a standard spade terminal would fit for test purposes but haven’t checked yet.
Bruce.m
Post by Bruce.m »
Pins are roughly 6mm wide so a 6.3mm spade terminal should fit, I think. There is a 4mm gap between the pins so enough room for one to be insulated? That would do for a test set up.
Paul H
Post by Paul H »
Yes that's what it'll be getting :wink:
