I've got a crank stamped H78, was told it was stroker 78mm.
But when I measure depth at TCD to BDC on any of the pistons I come up with 69-70mm
It is an 8 dowel, with massive 1 ⁷/⁸ gland nut.
Any ideas? It's not a forged stock crank, shows areas of welding.
How to identify crank
Re: How to identify crank
https://www.bing.com/search?q=VW+cranks ... A1&PC=LCTS
Page down to SSP (I think that is the letters anyway.
- AdminSteve
- Site Admin
Looks like a stock stroke aftermarket crank that's had counterweights welded on.
AdminSteve
AdminSteve
S&S Aircooled Parts and Accessories
645 S State College Blvd, Unit E
Fullerton, CA 92831
www.ssaircooled.com
(714)886-7636 Phone
Fullerton, CA 92831
www.ssaircooled.com
(714)886-7636 Phone
So with 94 jugs it will and should be a mean 1915.
I plan on running dual 44 webber.
What can I expect with the added/welded counter balance?
More rpm, low end torque.
- AdminSteve
- Site Admin
Its not gonna give you any real world benefits outside of a little smoother running engine.
AdminSteve
AdminSteve
Fullerton, CA 92831
www.ssaircooled.com
(714)886-7636 Phone
Fullerton, CA 92831
www.ssaircooled.com
(714)886-7636 Phone
If done properly… it won’t flex like a wet noodle above 5k rpm, which a stock crank does due to the secondary imbalance & lack of stiffness in the webs.
