Hi all. I have a 1971 supercharged 1600 beetle with a scat 35 cam. The problem with the car is that the exhaust smells ready ready bad. If you was to walk behind it the smell stains your clothes and skin for hours. There is no black smoke coming out the exhaust nor are the plugs black to indicate a rich condition. The car drives just fine as well. I have set the mixture screws on the Weber DCOE to give the fastest idle speed. Both barrels of the carb combine into one tube if that makes sense?
I was wondering if it had anything to do with the cam and the overlap or is it running lean.
I one heard that a rich engine does not smell but a lean engine does due to the different gases a lean engine produces, but I don’t know if this true or not.
So what can cause this smell?
Cheers all
Extremely smelly exhaust
Bruce.m
Re: Extremely smelly exhaust
No idea but my wife says i stink if I’ve been doing some engine tuning etc with the engine running (standing next to exhaust). Probably modern fuels without a Cat to filter out or burn up smelly vapours.
- Volky
Hi,
I run a 2109cc 1970 Turbo Bug and when I turn on the car in the garage and outside being next to it my clothes get smelly, too. No black smoke or any smoke, just smells. Also, I don't run any muffler, just a 6" tube from the exhaust flange.
I just have an extra shirt in the car at least, just in case.
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me...
t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
