Hello,
Since i have a working throttle body (ITB) build on my type1 mild engine (using motorbike ITBs, injectors, fuel rails), which is working okay, I’ve been thinking about possible future designs.
I will be making an intake for my type4 project but may consider another type1 prototype for fun.
My preference is for a single throttle body and 4 port injectors but i’m not convinced the CB end casting style is the best approach (& no good for T4)
Design1
would have a head mounted section with injector bosses, that would rise up each side & for a type1 would split so there are two runners. There would be a joint in those runners so the upper section could be quickly removed for easy spark plug access etc. the upper section would go into a good sized plenum (one per head). Both plenums would be joined by a large bore cross pipe above the alternator (type1 & type4 cali), with a central mounted throttle body. With a decent length of primary runners, it should provide good port inertia. Overall, it’s similar to the intake on a modern 911 but obviously with only 4 runners & some packaging problems to fit around the upright doghouse shroud.
Pros: primary ID can be sized for purpose & not excessively so (killing airspeed & inertia). Large bore cross pipe avoids nasty harmonics, hopefully . Single throttle body means no linkage balance issues, good throttle progression and easy Map based tuning.
Cons: lot of elements to design. If the lower intake is 3D printed, it needs isolation from head. The throttle will be lazier than a set of ITBs. Lower section could be made in metal but at higher cost, and rest could be printed.
Design 2:
This could use a set of generic IDF manifolds as the base (per head). On top a printed section in place of the IDF carbs, which has injector ports but no throttle butterflies. That section would have some length of primary which then combines into a plenum (per head), similar to design 1. Again, a large bore cross pipe with central throttle body would link the intake sections on each side.
Pros: less to design & print. Lower section are easy/ cheap to source for T1 or T4. No modifications needed to the metal for injector bosses. As above, simple tuning & linkage.
Cons: injectors higher in the port. Carb manifolds are typically larger bore than needed for most engines, reducing the efficiency & airspeed in the primary runners. More likely to have fuel fog in the plenum section at certain rpms, perhaps causing imbalance.
So, any input on the ideas above?
EFI Intake ideas - any input?
Bruce.m
Re: EFI Intake ideas - any input?
This is an old rejected prototype.
But id want longer primaries, bigger plenum and larger bore cross pipe.
Bruce.m
Cad render of the old (rejected) version.
- Paul H
Just use an intake off a late fuel injection T4 convert the throttle body to accept a TPS and make a stainless fuel rail to accept modern injectors
Bruce.m
Unfortunately with upright doghouse conversion my future type4 won’t take the OE intake parts. I did look closely at them thinking i could use the head part with injector bosses & cut off the runners pointing up, then add the rest. However the angle of the injectors & fuel rail would be very low and I think they would hit the side trays on a beetle.
Do need to order your T4 trigger wheel after the summer.
- Paul H
Well you can try to reinvent the wheel but the best and easiest is just stay with the IDF manifolds and go up and over from there
- Paul H
You could use these which are just injector holders if you want a single throttle
