Beetle upgrade to FI
Meresider
Post by Meresider »
73 bug non 1303.
Need to upgrade to 8mm, existing is easy but where do I add return line in newish tank, best way to add without causing swarf and ignition of vapour.
Will be using hose as final connect from copper lines.
Sent from my SM-S711B using Tapatalk
Bruce.m
Re: Beetle upgrade to FI
Post by Bruce.m »
Cb performance Tee piece fitting for under the tank. Or use a mexican beetle 1600i pump & swirl tank (chunky the find space for it however)
Meresider
Post by Meresider »
Bruce.m wrote:Cb performance Tee piece fitting for under the tank. Or use a mexican beetle 1600i pump & swirl tank (chunky the find space for it however)
Cheers,
6483 Billet Fuel Tank Outlet Tee https://www.cbperformance.com/product-p ... OxbJegvYnc
Just need a UK supplier Image
Bruce.m
Post by Bruce.m »
Add a few bits & bobs (keep it below £135 equivalent), then order direct. Shipping will be circa $50 but if the price of parts is under £135 (be conservative with the conversion rate) you don’t pay vat or duty. Above £135 you pay both on the total cost including the shipping.
Bruce.m
Post by Bruce.m »
If you are going EFI the CB “camsync” is great value. Combined with a crank trigger (VW speedshop make a great kit), you can have full sequential set up.
