Hi all, I've been building this tranny (Rhino) up for the last couple of weeks, and struck a little problem.
It has a quaife diff with 30mm output shafts and 37 splines, which fit the bus flanges.
Original diff's have a half round split spacer ring under the CV flanges. These don't appear to fit on the quaife...
I have the ones from the bus transmission, they fit over the shaft, but the width seems to be different.
Has anyone come across this too, and what was the solution? Straight on without these, or did you fit a shim?
Thanks in advance !
Quaife CV flanges
Typ 4
Re: Quaife CV flanges
Sorted. They don't have any shims under the drive flanges.
