Rear sway bar link bushings installation
papak
I have read that the trick is to heat the bushings in hot water to about 200 degrees and then press them in. I have tried this and it remains a real challenge. Any other ideas?
Re: Rear sway bar link bushings installation
Which ones are you using? What material? Also what are you pressing them in with?
This type of link bushing is tough on many cars. I use a bolt through the center with some fat washers under the head large enough in OD to not go through and a short length of pipe nipple on the other side with some decent non-petroleum lubricant on the bushing. Put a nut and fat washer on the bolt sticking through the pipe nipple...hold the head with a wrench an tighten the nut to kind of pull the bushing in.
Ray
Ray
Dishwashing liquid, I keep a bottle of Dawn in the shop for this sort of thing, works awesome on spark plug boots too for inserting the wires. A drop does wonders, makes putting a T1/T3/Bus windshield in a 2 minute affair with some soap covered insulated 12 ga wire for the pull cord.
