Mismarked R&Ps
Bruce2
Mismarked R&Ps
Post by Bruce2 »
I lifted this quote from Timmy from 4 years ago:
Casting Timmy wrote: Fri Feb 12, 2021 6:14 am ... I know I've opened one 3.88 "k" that was a K in marking only and the tooth pattern was definitely a G. So there are some mis-marked ring and pinions out there as well.
I recently opened up a double side cover IRS Karmann Ghia gearbox, code AN. It had a 3.88 R&P as expected, but the pinion shaft was marked K741 !!!
Anyone else run across a mismarked gear set?
