car wont start at all (HELP)
vdubna56
Post by vdubna56 »
im 16 and just got my 56 a couple of weeks ago. i have been told that the carb is at fault, i had it rebuilt and i installed it myself, but thats it. i have no clue about engines in general but everything seems to be hooked up right, but hen i turned the key... i just hear the car "choke" and the belt moves. what do i do?????
engine is 1600cc sp and carb is stock size i believe
thanks (in advance)
weno
Post by weno »
aloha. well i just got into the air-cooled circuit about a year ago. but have a lot of mechanic epxerience with other cars and especially on trucks. for it not to start could be a cause of a lot of different mishaps on the motor; timing, carb like you said, fuel lines, other stuff, but i don't want to discourage you. and you should always spend an extra 15-25 bucks for a shop manual specified for that certain model and year of the vehicle you own. either bentley or haynes. they have everything well mostly everything about any kind of car out there. and if you don't have that, go ask a well known mechanic you can trust. good luck. i know this wasn't useful, but just some pointers. cause i was in your shoes when i first started working on my first truck. and don't be afraid to ask the parents for an extra buck or two. good luck
Joe Goldthwaite
Post by Joe Goldthwaite »
It sounds like the engine isn't turning over. Is this correct?
If the engine isn't turning over, it could be that your battery is dead, your cables are dirty, the ground strap from the transmission to the frame could be disconnected.
If the car has been sitting for a while, it's probably just a dead battery. Hook up a charger for a while use some jumper cables.
Nailbiter
Post by Nailbiter »
Try Speedy Jim's procedure (after trying battery advice): http://www.nls.net/mp/volks/htm/eng_strt.htm
All a VW needs to start is compression, air/fuel mixture, and spark. This page will walk you through it. This helped me and I hope it works for you.
New (old) bug huh? Don't be afraid to get your hands dirty and have fun doing it. Image
[This message has been edited by Nailbiter (edited 05-17-2002).]
vdubna56
Post by vdubna56 »
thanks for the site, tips on the battery stuff, and of course the motivation. im gunna go and "get my hands dirty" saturday morning. i will let you guys know how it went...wish me luck(this is gunna be fun)
