solex 40s
njv
solex 40s
Post by njv »
got hold of a set of t4 solex 40s for my t4 engine conversion into my t3 sqr and figured if anybody new any details on how to tune these carbs you guys will are these carbs in the haynes for t4 anybody now of any web sites with a how to on it or the vw without guesswork mayby.
any help much appreciated.
Specky VW freak
solex 40s
Post by Specky VW freak »
njv
solex 40s
Post by njv »
no sadly these that i got are the pdsit 40s
Roland Kunz
solex 40s
Post by Roland Kunz »
Hello
Riechert is the correct address.
Those carbs can be used up to 115 HP ( I had a 105 HP 2,0 in a 412 Variant ) in fact Opel used one for a 90 HP engine.
First is to check if you have the 75 or 85 HP version and how good is there condition.
Bergen isn´t to far from Riechert, Theo Decker or Oettinger.
And it was very much guesswork, Hartmann in Stuttgart made it in 2 hours. Wrong seting will run to lean and your engine gets killed.
Grüsse
njv
solex 40s
Post by njv »
there not any good at the minute went to rebuild and the idle screw snapped of in the housing even after warming and oiling i was badly gutted but looks like i got a handle on some dcnfs that should fit undr my t3 deck sweat .
ill see how it goes with the pdsit 36-40 as im sending the butterfly of to a pro to see if it can be fixed and i may also be getting a second set of these carbs also
working on the principle i can chose the ones i want to use and sell the rest nicely rebuilt.
Roland Kunz
solex 40s
Hello
Isn´t it funny two germans writing in runaway english ( denglish ).
Now I prefer to stay on the board as others may have input or we can leave some footnotes for further discussions.
The PDSIT 40´s have some weak points. Also original VW units are quite rar they only came 74 on the 412 & 914. On the 914 the survived up to 76.
I good rebuild will run in costs where JC Whitney, Eurorace or Red Lion have complete low profile kits. But the low side is most of the in the uS sold carbs are made in Mexico or somwhere else and are dirt cheap and sometimes disapier over the years. Also the linkage and the manifolds are also pooorest ever seen this side from the moon.
So on the end you can get some serious stuff from the staates or in germany and pay the same amount or you get dirt cheap things an will trash them in some years.
Hope others on this board have input on that.
A good carb specialist will preset the carb if you give them your engine data so they are just bolt on and synchronizing and some fine adjusting but no jet work. ( Ahnendorp & Red Lion managed good work ).
Grüsse aus Porsche City
Roland Kunz
solex 40s
mel
solex 40s
Post by mel »
I have a pair of solex 36-40 pdsit carbs fitted to my type4 engine did you have any luck with your quest for more infomation that you could past on to me? thanks Mel
