rear tire wear and drop
lins karmann
Post by lins karmann »
the inside of both rear tires are worn. i dont know if the car has been dropped or not. it measures 11 1/2 inches from hub center to top of wheel arch. is there a way to align it to prevent wear. i dont want to raise the car if i dont have to i like the way it looks. it has riveras with 165r15. can you fit a bigger tire without rub ? its a 70 vert. thanks for any input.
Todd
Post by Todd »
LK,
Sounds about right, not too far off anyhow. Reckon your torsion bars are a bit 'tired' allowing the rear to drop a bit and the camber to be affected. An adjustment might help. A bit of a pain, but well worth it. Theres many post about it here.
Todd
