Engine swap in a Diesle Vanagon
stevestromberg
What is the bolt in swap for a watercooled inline VW motor. Steve
Derek May
Check out the options:
new 2.0 L kit, bolt in solution, but expensive -- I think its a 2.0L Jetta engine. Its the same engine that "Caravelle's" (Vanogon by another name) have in South Africa.
http://www.tiico.com/prod04.htm
Various adaptors from Kennedy Engineering, including a subaru engine adapter:
http://www.kennedyeng.com/
More info on subaru swap:
http://www.mcn.org/b/roadcow/convert.html
Here is a guy who put a chevy V6 in a Baywindow bus -- guys, check out the spare tire up front -- ingenious!
http://home.earthlink.net/~dmh012/v6vwp.htm
How about a GTI engine? With a Diesel, you can swap the oilpan and a few other key components to lay a rabbit engine on its side back there. Check this out:
http://www.bcn.net/~limbo/GTIbus.htm
Or Better yet, a VR6 engine:
http://volksweb.relitech.com/../helmut/ ... 6-engi.htm
But this is probably the links page that has all the stuff you want to know:
http://www.volkswagen.org/vanagon/engineswap.htm
Goodluck.
Goodluck.
Brutus
I think you're already set up for the inline 4 water cooled physically - just the electrics and fuel stuff.
Course, if I had unlimited time and money (who does) I'd swap in the TDI and have the ultimate van (IMHO). Good luck!
- Bobtail
There's also this company which does just that TDI 4 and 5 cyls
http://www.syncro-bernd-jaeger.de/TDI-U ... umbau.html
www.centralvwaudi.com
