transmission oil
unclejohns78
transmission oil
Post by unclejohns78 »
Howdy,
Is it difficult to check and change the transmission oil on my 78? In Bentlys, it looks very straight forward and simple, but John Muir suggests leaving it to a shop. Is this something I should be able to tackle myself?
Brent
78 Bay
germansupplyscott
transmission oil
Post by germansupplyscott »
uncle,
if you have a manual trans it is easy. you might need a filler tube for the oil, but you can easily improvise something. i don't know about auto.
scott
Thumposaurus
transmission oil
Post by Thumposaurus »
When I changed it in my '73 the hardest part I had was getting the drain and fill plugs out, and I had the proper tool too, I had to just keep cranking and cursing at it untill it finally loosened then it was just a matter of letting it drain and filling it back up. The old gear oil stunk too, I can't even describe it.
Pillow
transmission oil
Post by Pillow »
Most people never check or maintain their tranny oil properly. Usually it is always burned up and stinks something horrible.
You will need a gallon jug of the stuff and if you have an automatic get GL-5, but if you have a manual shift you MUST USE GL-4. NAPA has it or can get it, it is a Sta-Lube brand product about $12 a gallon.
Be sure to get the little $5 pump assembly that goes with it. Otherwise you cannot get it into the tranny.
I would like to recommend a shop to do it, but very few shops will have GL-4 and then you run the risk of them stripping the threads on the plugs. To me not worth it.
Adrian Pillow
'66 VW Westfalia - "Biscuit"
rich2481
transmission oil
Post by rich2481 »
Gear oil just plain stinks, I know Auto Zone here in Tucson sells a cheap pump that screws into the gallon jugs of gear oil, I have had to replace the plastic hose once because the oil left in it over the years has made it stiff, plus I got to make it longer and dont have to try to pump it from under the vehicle
