I just installed my raby built stock 2 liter with the stock fuel inlection.It is a 78 westy that ran on the fuel injection before the rebuild.My question is about the vacume line that runs from the dizzy to the throttle body.This line has a tee in it for another line to connect to it,does the deceleration valve small vacume line go to it or the small one on the aircleaner(evap emission control valve)
I also have the vacume line that runs from the fuel pressure reg to the manifold vac port that has a tee in it for the other one.I dont want to start it for the first time till I get them correct.Please help!Thanks Ken
Help vacume line mix up
regis101
I shot a reply under the FI section. Happy Trails
kps73
Thanks that did it.Having problems getting her running,see fuel injection forum,hot wire fuel pump.Thanks Ken
