Setting deck height on 40hp?
Bill Richardson
Post by Bill Richardson »
Getting ready to start the assymbly of my 40hp and got to thinking about how to go about setting the deck height.
On a dual port one would use shims under the cylinders but how do you do it on a single port motor?
Have not cc'ed the heads yet but what is the suggested CR for a stock 40hp?
CptanPanic2
Post by CptanPanic2 »
Why can't you still put shims under the cylinders on a single port motor?
Brian
Bill Richardson
I had heard that you can't use shims because there is no free play in the intake manifold like there is on a Dual Port.
When I think about it, not sure if the added width due to shims would be enough to worry about.
vwnate1
Post by vwnate1 »
Cylinder base shims are the correct way to set deck height on the 40hp engine , getting hard to find , RIMCO will make them up for you any size you need . DON'T use paper base gaskets !
Properly set CR (6.5) in a 40hp will make it run like a raped ape and stay together too .
Have fun .
-Nate
Filth & Greed Imports
(the LAST honest VWshop)
Bill Richardson
Thanks!
Glad to see a fellow VJMC member on here.
