HD Valvetrain
73_1600
HD Valvetrain
Post by 73_1600 »
Hi everybody-
First off let me tell you a little about my bug. About 2 months bought a '73 Bug with a fresh 1600 motor in it for $900 and over the time I've been looking to improve the performance of the motor.
Today my friend took me to a junkyard where he showed me a bug which had a long block sitting in the driver's seat. I was going to just buy the heads off of it so I have a spare set when I port and polish my heads in the near future. When I pulled the heads I discovered it had alum. push rods and slip in 87mm jugs in the motor! the rear end of the motor looked as if someone had taken a sledge to it so I decided to just take the pistons out of it. Now I was looking at the heads tonight while I was cleaning them up and noticed the valve springs and retainers, look beefier and they are a nice shade of aluminum then the stock ones. SO I was wondering if there is anyway to tell if these are HD valve spings. I wouldn't be surprised if they arn't considering this motor had alum. pushrods and 87mm jugs on it. who knows what was inside the motor.. hmm
thanks and sorry about the length.
matt
1973 VW Bug
Rebuilt 1600cc motor
009 Dizzy
Bugpack Header
Bugpack Single zoom tube
Bugpack J-Tubes
Bugpack Urethane Shift Coupling
BugPack Short shifter
Empi Urethane Tranny Mounts
Empi Breather Setup
Empi bolt on Vavle Covers
Empi Oil spout w/ breather
Empi High Flow oil pump w/ filter
Future:
Empi Windage SS pushrod tubes
Ported and polished stock heads
adjustable front axle
lowered kyb gas adjust shocks
lowered ball joints
urethane torsen tube seals
urethane torsen arm bushings
