Carb setup? Porsche to VW
Derek56Oval
Post by Derek56Oval »
I saw some Dual Solex (PII40-4)carbs from an early Porsche on ebay. Would these work with a VW engine? Would there be any advantage to using a setup like that? I am planning my big engine build (1914cc) and need to decide which setups i am going to use.
bugboy
Post by bugboy »
i'm sure you can use them if you can get manifolds that will fit. but it also depends on what spec engine you build. 1914 can mean so many different things.
1969 st. beetle
Bare
Post by Bare »
Owned a '59 Porsche 356A coupe once.. It had those Solex carbs.. they were a real pain to keep healthy.. I wouldn't wish those on anyone.
74baja1915
Post by 74baja1915 »
i don't know about the other carbs but i have a 1915 and i use the dual 44 webers and they are sooooo sweet
If its not broke don't fix it, but if it can be made better by all means do it!
Richard Hunt
Post by Richard Hunt »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Derek56Oval:
I saw some Dual Solex (PII40-4)carbs from an early Porsche on ebay. Would these work with a VW engine? Would there be any advantage to using a setup like that? I am planning my big engine build (1914cc) and need to decide which setups i am going to use.<HR></BLOCKQUOTE>Do yourself a favor and buy a good set of weber or Dellorto carbs, parts are readily available, the P11's are a pain.
Rick (M.C. Drag Racer)
