TB angle
John BUG2180
TB angle
Post by John BUG2180 »
Can you mount a TB (say Mustang) at any angle. Or, slight angles. For clearance problems or turbo alignment?
John Springsteel
VW drag racer
BUG2180@aol
Chuck Schneider
TB angle
Post by Chuck Schneider »
Hell yea. The beauty of fuel injection.
Sharkey
TB angle
Post by Sharkey »
Yep. I've seen "downdraft" and "updraft" throttlebodies, as well as the typical "sidedraft" Mustang 5.0 TB. This allows you to mount nearly any TB in whatever position you want in order to ensure proper clearances and throttle cable operation.
ray greenwood
TB angle
Post by ray greenwood »
Yep any angle will do...just try not to get a 90 degree right before the entrance to the runners, without having a plenum box behind it. You need to have some space behind a sharp angle to "straighten" the air flow to get rid of as much turbulence as possible before you contact the runners, or else you may lose some velocity trying to get it all smoothed out in the runners. Ray
John BUG2180
TB angle
THANKS!
John Springsteel
VW drag racer
BUG2180@aol
