L-Jet in slightly hopped up 1.8
flat4-4now
Post by flat4-4now »
I'm rebuilding a stock 1.8L LJet 914 ('75) and plan to increase the P&C's from 93 to 96mm and use a stock grind cam, maybe Webcam #73. Going from 1795cc to 1910cc isnt a huge jump, but will that affect the A/F ration at all? should I worry about leaning out too much? I'm collecting as much literature as I can and am trying to understand modifications to this FI system. Anyone have any thoughts?
germansupplyscott
Post by germansupplyscott »
what is the number on the injectors?
scott lyons
flat4-4now
the PN is 0 280 150 112
Its for a 1.8L system
I see also a "957" stamped on the injector
Mueller
Post by Mueller »
I put a stock 914 L-jet on my euro-spec 2.0 motor...never had a problem.....
flat4-4now
Mueller: did you just slap on the LJET and it worked? I supposed you used 2.0 injectors? and was it a stock 2.0?
flat4-4now
oh yeah, i see its a euro spec, so a little higher comp.
Mueller
Post by Mueller »
I used the 1.8 injectors mounted on the 2.0 intake plenums...
I've also had a 1.8 with a big bore kit
(1911) and used the L-Jet as well with no problems.
The only reason I got rid of the L-jet on my 2.0 is that I built a Megasquirt FI unit for it.
Mike
flat4-4now
Was your use of the 2.0 intake and plenum a calculated one or arbitrary? Does that simply move more air into the system? I've been reading alot of Greenwoods old posts and theyve been helpful. It looks like the LJet can handle a modified displacement just about to 2.0. I just want to be sure it will work and what adjustments I'll need to learn how to perform on this system.
Mueller
Post by Mueller »
I used the 2.0 intakes and the 1.8 plenum...mostly 'cause that is what would work the fastest to get the car running.
I would have needed a 90° elbow to mount the airflow meter to the 2.0 plenum.
The '76 912e's used all the stock 2.0 intake parts but with the L-Jet as well since the factory made the correct elbow.
75alive
Post by 75alive »
Does anyone know the lift/duration/etc specs for the stock cam? I'd like to compare it to the web 73, but cannot find these figures anywhere. Thanks
75-1.8-Ljet
