Hey, I posted this up on the Off Road Forum, can you guys help me out? J
http://shoptalkforums.com/bbs/NonCGI/Fo ... 00357.html
Wanted:
-Beige Upholstery for 68 Ghia (front & back)
Truck Bed liner on my Thing
LB181
The POR Primer should be fine. The bedliner should stick to it because they have been using that POR on hotrods a lot to keep rust from forming. What you can do is just try it on a srap piece of metal or somewhere it does not show to test it out. I would think the primer would be fine. I am planning to do the same thing.
LB181
You probably already checked it out but I read on the POR Website FAQ that: "Tie-Coat Primer is not a reactive coating (as is POR-15, which reacts to moisture), but its revolutionary adhesion promotors make it an ideal interlocking prime coat between POR-15 and various topcoats."
Hope that helps.
Hope that helps.
74Shagenwagen
See my replies in the Interior Exterior forum and also the Off Road forum.
GhiaRacing
Thanks, I put my reply on: http://shoptalkforums.com/bbs/NonCGI/Fo ... 00357.html
J
J
GhiaRacing
I put my reply on http://shoptalkforums.com/bbs/NonCGI/Fo ... 00357.html
Thanks, J
Thanks, J
