A few weeks ago I posted about wheel/tire size and Bob Ingman was good enough to enlighten me about yet another issue.
I have now purchased the Empi style 8 spokers (15" x 5.5") and had planned to go with some 205 75 15's all the way around.
The tires on the car when purchased were 215 75 14. Do I have to go with 75 series tires this time or can I get away with a lower profile? Just wondering since I am not planning to go off-road.
[This message has been edited by Advokat (edited 02-12-2003).]
Tire size
- Bob Ingman
Tire size
Avokat the low profile will actually simplify things for you. Its the big tars that are hard to fit.You will have to allow for about an inch to compensate for the wheel adapters. Post some pictures on the Gallery thread when you get set. Good luck. Bob Ingman
[This message has been edited by Bob Ingman (edited 02-12-2003).]
BobMiller
Tire size
Advocat
You didn't mention if you were going to raise the front of your car. With about a 3" lift, and a little contouring of the back of the headlight bucket, you can use about a 27" tall tire. I am using P215/75-15's on 6" wide rims with only about 1/4" positive offset.
When you fit new rims and tires, the fact that they clear then isn't enough. The tire appears to get larger when it turns, that is it moves forward some, On top of this, add what happens when you hit the brakes in a turn, that's the worse case scenerio you have to watch for, the front of the car comes down and the tire and the back of the headlight bucket become intimate with each other
It's a sudden surprise when these two come into contact and the wheel gets jerked in that direction.
Been there, done that
1966 MANX SR2 (Karma Coachworks), 1974 VW THING
- Bob Ingman
Tire size
Bob do you think he is going to install a low profile tire and want to raise the car? The two do not go together.
Advokat the rear has plenty of room for the adapters so should be fine there. I`d say that since you have no adapters in front that any 205 tire will go on just fine. Good luck. Bob Ingman
BobMiller
Tire size
Advokat
Then the real answer is Yes, you can use the 205/75-15's if you are careful. There is still a possibility of tire to headlight bucket contact when braking during a turn.
As an aside, There is no shortage of raised and lowered cars in Southern California with low profile tires. It's often a matter of choice, style, whats currently cool, etc, not need...
JayR
