Okay so the T5 uses the standard T4/Vanagon hydro lifter, but with a T1 cam.
Is it possible to put a T4 solid lifter in and run it with a standard T1 cam?
I would assume so, but just wanted to get a feel... Saves the process of sleaving the lifter bore in the case.
Adrian Pillow
'66 VW Westfalia
'79 Porsche 911 SC - FS
VolkSport Kafer Gruppe
Lifters ?
Type 5 Joe
Lifters ?
Yes that's the way to go if you stay with Type IV lifters.
More aggresive, long duration Type I grinds will require a lifter W/ a larger face (Type I).
- Joe
- Joe
Pillow
Lifters ?
Excellent, that is what I was thinking.
Granted I will probably end up keeping the hydros and lame hydro bump stick... For a bus, easy is good.
Amazingly enough the T5 did not show signs of wear like the T4 motors do with the beat up cams and lifters.... Maybe the T1 cam is a better design?
Adrian Pillow
'66 VW Westfalia
Adrian Pillow
'66 VW Westfalia
Type 5 Joe
Lifters ?
Superior Design.
What did you think of that rear thrust bearing? Your's is a 2.1 Right?
I would think about going to a new web-cam, new lifters, ect...
Pillow
Lifters ?
Very interesting main bearing... Weird, but I guess it works.
I plan on getting a reground/new hydro cam and new hydro lifters. Nothing really exciting though. Again jsut a boring bus engine, no high HP or revs needed.
Thanks,
Adrian Pillow
'66 VW Westfalia
Thanks,
Adrian Pillow
'66 VW Westfalia
