This is for a 2.1 case which has a pre-bored hole just below the normal T1 return tube location... Is this hole okay to use as a return line?
Here is the T1 process: http://bugman.50megs.com/FilterTech.html
Now here is a shot of the stock 2.1 T5 opening: http://www.gearheads.dk/oxybilleder/Blo ... _front.JPG
Here is a 2.1 tapped like a normal T1: http://www.gearheads.dk/oxybilleder/oxy ... _front.JPG
In my case I will run a Berg pump cover on a 30mm Schadek AL pump that is plugged. The oil filter will remain in the stock T5 location (unless the muffler gets in the way?).
Hopefully a simple question, I just do not want to hinder oil flow by using the lower "pre-tapped" spot if it sucks...
Adrian Pillow
'66 VW Westfalia
'79 Porsche 911 SC - FS
VolkSport Kafer Gruppe
