S/F bigger bore/ headstud relocating
Carsten
Post by Carsten »
Looking at some other posts regarding stud relocating. I know that the 910 and maybe Angle Flo 101,6 heads will " Fit" the WBX heads stud spacing.
My problem is that I have a really nice set of S/F 94mm heads.
Will these accept a +/- 105-108mm register bore without breaking through? (Welding up the old stud holes, to get a full seal surface.)
also relocating the headstud holes? Is it nessesary to strenghten the areas (i.e) for the upper outer studs?
Hope for some good info!
Pocket rocket? Badbug?
Carsten
(wanting 2540ccm)
alan harland
Post by alan harland »
I believe Strictly German Autowerks still has a set of 101.6 SF heads they made. There is allot of welding involved in getting SF that big. Call them at 503-233-0030
