Were these ever offered as stock on the wasser? If so, what year(s) were they available?
Thanks!
Matt
Wasserboxer 1.25 ratio rocker arms?
wbx
a little more detailed info, please?
Hey Steve,
Thanks for posting so much on this list. Are you running hydraulic or solid lifters? If hydraulics, do you happen to remember what your pushrod length ended up coming out to?
Also, did you have any valve cover clearance problems with the 1.4 ratio rockers, and finally
have you had any problems with valve springs being able to keep up with the ratio rockers (assuming you are running stock valves and springs?).
Thanks... it looks like i am eventually wanting to build up an engine much like yours.
-Damon
-Damon
Any opinions on the Bugpak 1.4s?
(Longevity wise)
The price is right, they look good, but I personally don't like needle bearings, a pressure fed bronze bush would be far more reliable (as a mechanical junkie)
Any thoughts?
(something is going in the Vanagon... Scat, Bugpack, or Berg)
(Longevity wise)
Any thoughts?
