Hey all, got a clutch/transmission question for you all today: When I release the clutch to get going in 1st gear, the clutch engages pretty quickly at one spot, making the engine want to stall if I'm not careful. She's totally drivable, I just hate to race the engine while easing out the clutch to get her moving. All other gears engage very nicely, and there's really not much play in my shifter/linkage (feels about right).
A couple of things to consider: I just had a new clutch plate installed when the engine was out and being rebuilt. Could it just be new and extra stiff? Also just had new engine & transmission mounts installed, but the hard engaging is still there, so a loose engine/tranny is not the cause.
Anything you can think of for me to check would be greatly appreciated.
Clutch grabbing hard in 1st...any ideas?
BobMiller
clutch grabs
ChinaCat
I would look at the flexible clutch cable guide tube that runs between the pan and the transmission. This must have a slight "dip" in it to prevent chattering. I believe about a 1/2" dip is normal. If this wasn't installed correctly I suspect you would see the problem you describe.
Bob Miller
Riverside, CA
Bob Miller
Riverside, CA
Guest
