How much horsepower?
tomkisner
Post by tomkisner »
Rimco super rods...$165.00
Offset grind stock 2.1L crank to 78mm stroke chevy journal...$200.00(very safe way to increase torque/power,Requires aftermarket rod set.)
Gene Berg stock or Perf. hyd. Cam grinds...$70.00
Performance exaust systems!...$200.00
Lighten & balance stock flywheel...$140.00(exch. ONLY!)
Cutsom JE Pistons from 94-100mm...$600.00
Bare Case...$300.00
Drill & Tap...$27.50
Magnum 44 40x35 bare pr...$280.00
Stage-4 ALL OUT STREET 44 x 37 Welded & re-located 12mm spark plugs,Chevy Springs & Retainers,Welded & Properly ported Intakes for port velocity,First fin Decked for Compression,Reshaped Combustion Chambers,D-Ported Exaust,5-Angle Grind,Bored to 88 or 90.5mm...$700.00ea
Probably with bigger injectors 2 what type of horsepower with say 96mm Bore?
conradk@mac.com
Lighten Flywheel?
Post by conradk@mac.com »
Why would you light the flywheel? Are you going to drag race your brick? ;-)
The crank/rods combo sounds like what I want to do though... If nothing else for more torque, better reliability in the rod mains.
