Here is the latest plan. Low compression 7:1 for the start so maybe I can add a low boost turbo later for the CIS FI. Probably ripped from a Saab.
Anyway I am thinking of using a T4 Bus 2.0 piston with a dish or the stock 2.1 low compression piston. Both with a tight deck for good "squish". I really like the 2.1 design so hopefully heads do not need cut down to the bone to get this to work.
Okay the questions:
1. What is the 2.0 T4 bus dish? I think 15cc?
2. What is the 2.1 T5 USA low comp dish?
3. Pin height diff between 2.0 T4 and 2.1 T5? (I should know this, but I do not)
That is all I can think of for the moment
Thanks,
