Hey Thingers
Are Thing axles unique or are they the same as Type 1?
I am thinking of buying Thing CV's from someone who has them avaliable and the seller is interested in selling the axles also for a few bucks more.
Is there any offroad performance advantage to Thing axles to make buying these worth it? The intended use is in a Class 11 style beetle sedan.
(not a true class legal racecar)
(term "racecar" used for identification puposes only, not to be confused with something actually fast)
Thing axles: unique or same as T1?
- Class 11 streeter
- prerunner1499
You could find a junk yard porsche 924 and use the rear arms, axles and cv's from that... The Thing and type 4 CV are the same outer diameter, and the 924 stubs are type 1 size but type 2/4 cv size splines on the axles. The 924 arms are a dirrect bolt onto a bug, from what I've heard and read here.
Kevin
Kevin
danfromsyr
the CV diam. and bolt pattern are the same as my 1989 cabriolet inner CV the larger of the watercooled inner CV sizes.. I should have tried to slip the joint onna aircooled axle when I did my boot fix..
FYI. I put a T-2/thing CV boot on my cabby as I had a few instock and was ina bind for a boot swap late last night. the inner joints don't need to articulate as much as my baja's does with thing axles.
