folks,
i'm rather new here and have been doing a tremendous amount of reading...thanks for the great questions and more so the superb answers.
my question has to do with a bug IRS chassis going under a 68 ghia, which i'm building right now.
i've read other posts that says that the chassis will work if i buy and re-weld KG pans on it. is that correct?
also, what is the difference btwn the bug and KG pans other than width? could the car still bolt up
it's hard finding a good donor KG IRS chassis in the middle of the sea. bugs, however are rather plentiful and cheap.
mahalo for you help.
bj
bug IRS on a early KG
- Soul
I know from first hand experience that the numbers on the body and the pan have to match in HawaiiMarc wrote:Better check with the authorities to see what paperwork they'll need. I know Hawaii's pretty strict about "Reconstructed Vehicles" (you have to get an inspection and a permit just to change the size of your wheels - unless you're a cop).
Guest
thanks for the replies. i've been away in New Hampshire for two weeks.
i'll check here about the numbers matching. i've never had anyone inspect or heard of anyone inspecting for the pan serial. maybe i could graft it?
as long as i know i can use a bug irs pan on my 68 ghia i should be alright. there's a really cheap 70 bug for sale. what luck on my first day back home!
mahalo
bj
mahalo
bj
