Stroke
slyscreename
Stroke
Post by slyscreename »
What is the largest stroke that can fit into the case with machining within reason?
Badbugtwo
Post by Badbugtwo »
The stroke that you can run is the same as a type one case. The distance from the crank and cam is the same. Although the case is a little wider the "roof" of the case appears to be about the same as a type case.
I am running an 86mm crank in mine and I am sure you could squeeze an 88mm or 90mm in. But from what I understand things get pretty tight for those that have done it in a type one case, so I assume it would be the same for these.
Jeff Rogers
http://www.badbugracing.com
9.35 @ 145
marcotheturbosteamengine
Post by marcotheturbosteamengine »
the Water boxer case has a higher roof to the case and is also wider, the problem you incounter is the cam, lots of clearence needed to the cam if you use stock VW big end size.but 90mm is defiently posable :D
Guest
Post by Guest »
thank you very much I think I'll go wit a nice 86x96 motor. But where can I get 96mm pistons Types 4's don't work right?
kit
Post by kit »
try looking on keith black's site... cannot remmeber the URL.
96mm pistons are from either a chevy or oldsmobile V8 I think.
kit
Guest
Post by Guest »
Aircooled.net is going to have 96mm enhanced combustion pistons. With a set of those in a C in height config., you could have a nice narrow motor. Marty has 5.7 rods, 86 crank, and it is stock width (with C squishies!).
Stock width with or without water jackets?
2489 cc essentially without machine work (water cooled)
John, if you're listening...;-)
I KNOW you're payin attention...
