I just received my 5.5" chromies, what size tires will work well on a stock, non lowered, Ghia. I don't want any tire rubbing problems. Should they be wider in rear, or same all around?
Thanks,
Jeff
5.5" Wheels, What tire size?
What's the backspace on the new rims? There are quite a few tire sizes which are legit on a 5½" rim, most of the time how wide you can go will be determined by how far out the outer sidewall will end up.
195/60-15 is probable (~7-2/3" wide at the sidewall, ~24.2" tall, roughly 5" shorter than stock).
- Plastermaster
5.5 Chromies have 35mm backspace. Check out www.tirerack.com for info on the science of wheels and tires. Ghias sometimes are not exact in the relation between face of hub and inside of fender. Take measurements of what you have now and figure what you can do. IMO 185 is a nice coprimise between wide, clearance, and tire roll.
Ron
Ron
Guest
