How long are your rods?
Russ1302
Post by Russ1302 »
I'm trying to figure out a good combo, and need to know some rod specs. Can anyone tell me the length of 1.9 and 2.1 WBX, and stock T1 rods?
Russ
marcotheturbosteamengine
Post by marcotheturbosteamengine »
there all the same length but the WBX rod has 24mm small end, everything but that is the same!
Tom Notch
Post by Tom Notch »
5.394"
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Bruce2
Post by Bruce2 »
137mm
tommi nylund
Post by tommi nylund »
I think you can calculate the optimal con-rod lenght to your stroke like this:
Basic factor (I don´t know what it is called in english) should be between 1,7 - 1,9..
So if you have 76mm stroke for example, you must do it like this:
76 * 1,8 = 136,8mm (about 5.39")
Hope that helped?
