I'm going to replace my Thing's complete brake and fuel lines- anybody got any advice for me on bending or fitting the solid front-to-rear lines? How difficult will it be replacing all the lines- special tools for connecting fittings etc.?
Also- where can I buy the front-to-rear FUEL line? Can I just order another front-to-rear brake line and use it as the fuel line?
Thanks, JPA
Replacing front-to-rear fuel and brake lines
jpashley
- Bob Ingman
JP the parts you need should be available through either The Thing Shop or Things Unlimited.
Are you speaking of the fuel line in the tunnel as well. If not any auto parts store will have fuel line and any VW shop will have the cross body brake lines. The lengthwise section can probably be made up for you locally as well. Let us know how this develops. Good luck. Bob Ingman
jpashley
- MNAirHead
Howdy.
Bending the lines is fairly easy... the keys are not to bend too quick and do many smaller short pressures on the lines. With a little patience, you'll be fine.
Brake Lines for a bug are commodity car parts.... you'll be amazed at what a new set of lines and hoses will do to the stopping power of your car.
Timmy
Timmy
jpashley
