I have dismantled a half dozen cars this year. On my second Thing a 1973 model. It has a Gas Heater. I pulled the heater out today and I have it in the shop. The heater is extremly clean, no rust inside or out. I conected it to a battery and the fan ran perfectly. All the wiring is intact, all the relays look like new.
I want to know how to test it. Does it need the gas pumped in or does it siphon it from the tank? I also need a wiring diagram to see how it is connected.
I plan to sell it but I hate to put it on eBay. What is it worth?
Thing Gas Heater.... I got a good one.
- Bob Ingman
Capn the 73 thing has a gas heater that is fed by a T coming off the gas tank. It has an internal pump that is responsible for supplying and regulating fuel flow.
There is a gray wire from the timer that is the power sourse. Run that to a switch and ground the heater to the opposite side of battery.
I have a friend that is a long time VW guy. He has tested gas heaters in his shop from time to time and I will give yoiu his email so that you might ask him directly if needed.
accu_tech_inc@yahoo.com His name is Joe Timberman. Best of luck. Bob Ingman
