Are the rear drums a "thing only" part...or will an early model bug drum work. I think I remember reading that the stub axle is beefed up and has a larger diameter at the splines.
Also, I need to replace the steel brake line from front to rear. Will the line that is sold for the bug work? Is the distance the same?
thanks,
mstatedog
rear drum & brake line
