so cal wide five disk brakes
four2fight
I am thinking of buying a set of so cal's wide five brakes for my thing. Has anybody bought these, and what do you think of them. I really want more stopping power!!!
Thanks, Four
Thanks, Four
- Bob Ingman
Mattt
I have a set. Not on yet. Almost ready to go on. I had to have the 12mm lugs drilled/tapped for 14mm. Just got that handled last week. Sadly, you cant use 14mm press in studs with these. You have to use screw in 14mm.
Ill have them on in the next month. Ive been debating about going 6" wider beam, and if I go for it, this is the ideal time since all the brakes will be off anyways.
Ill report in once they are on. Ill tell you this right off the bat, they are much heavier than stock drum setup. Im talking like twice as heavy according to my scale. I spoke with SoCal's tech support on this, they claim its not a problem for the Thing spindles & arms.
- Bob Ingman
Mattt I`m sure that any additional weight will be more than compensated by your use of alloy wheels. I see people running big steel wheels alll the time and getting away with it. You know what those things weigh.
Didn`t know they require screw in studs though. I love my press in 14mms but would give them in the front for the discs. At least they are five lug. Best of luck. Bob Ingman
Mattt
- Michael Basso
more stopping power
Maybe you just need new drums, a good brake fluid flushing and some new brake parts.
that would be my recomendation
the new socal disc brake kit will require you to install new wheel cylinders, new hoses and a new master cylinder anyhow.
I just went over a car with all new brake parts and now I can stop on a dime.
without any major modifications.
I would also be happy to sell you a socal disc brake kit, and it would ship from CA with no tax, because i am the seller. And i am in ny.
- Bob Ingman
Mattt
Re: more stopping power
I do agree that properly functioning drum brakes work okay. My primary Thing has great drum brakes. They stop very well.....for drum brakes. Its all about adjusting them correctly, having new fluid, good wheel cylinders & new brake hoses.Michael Basso wrote:Maybe you just need new drums, a good brake fluid flushing and some new brake parts.
I have another Thing with drum brakes that absolutely SUCK! The car doesnt stop and when it does, it doesnt stop well or straight.
In any case, the discs will definitely work better than even the best drum setup that is functioning perfectly. This is even more true when in wet conditions. Discs are current technology, drums are old technology. Also, drums have to be constantly adjusted, discs need no adjustment.
Mike, what do you mean above..."the new socal disc brake kit will require you to install new wheel cylinders, new hoses and a new master cylinder anyhow"
There are no wheel cylinders with disc brakes. As for the M/C and hoses, I asked SoCal tech support if there are any differences between the parts in the kit, and regular drum parts, they say there are not. They just like to sell a complete new kit so everything is brand new with their disc brakes.
Mattt
I agree with screw ins having their downfalls, but thats all they offer with these discs. If you want press in studs, go to CNC, or Neal, but be ready for the price difference $900/set. Im going to use a stud setting compound, basically very tough lok-tite made for studs that you dont want coming out. Tacking them is another option.Bob Ingman wrote:Mattt I`ll drill and tap but you can bet that I`ll also tack. There is no way I`m going to use screw in studs. Been there . Done that. No bueno! Best of luck. Bob
- Bob Ingman
Matt I too am convinced that the SoCal kit is the right product for the money and will be installing it this year. I have in the past used screw in studs but never really with any success. I tried lock tight on them and anti sieze on the thread/nuts but still some of them would come out with the nuts. Thats why I planned to tack them. I`m sure a single bead on each stud would be sufficient. Oh well its still a ways off yet so we`ll see when the time comes. Thanks for sharing the info with us about the SoCal kit. Best of luck. Bob Ingman
Mattt
The only kit that I know of that comes with drop spindles is the CB Perf. kit. We are not talking about that kit.rfoutch wrote:My problem is that most of these kits come with drop spindels and I am raising my thing
Will they fit on the standard spindels? or do you have to use the ones provided?
Randy
What are "most of these kits..." that you mention?
You cant even use that kit with the drop spindles anyway because the bug ball joint arms/spindles are different from Thing ball joint arms/spindles.
- Bob Ingman
