Ray CV part # and compatability with Thing
alsehendo
Post by alsehendo »
VW part no. 211 501 331B is this the part # for type 4 CV.
Is this also used in thing? see below?
VW part no. 113 501 331D
Bug and Bus CV joints don't have the same ability to operate at as severe a drive angle as the type 4 joint used in the type 181. Thus will operate up to an angle of approximately 21 degrees, versus 17 degrees for the Bus joint. However, as a temporary fix, the Bus joint (VW part no. 211 501 331B) can be made to work.
The type 4 and 181 CV joint can be fitted to a Beetle transmission. Just use the transmission flange from the original on the new transmission. It's only this flange that is different on the trans.
Is this what I want below for my new Thing Ray?
http://www2.autopartsauthority.com/part ... +Joint+Kit
