T5 heads...
MASSIVE TYPE IV
T5 heads...
Looks like with some slight mods my new TIV heads(with TI exhaust ports) will be a direct bolt on to a T5.
They will allow up to a 108mm cylinder size, and have healthy finnage..
More when I make sure that it will work!
- Badbugtwo
Re: T5 heads...
Well if you need someone to test them out on....MASSIVE TYPE IV wrote:...More when I make sure that it will work!
MASSIVE TYPE IV
Type 5 Joe
MASSIVE TYPE IV
Type 5 Joe
So the valves will shift over easily too? Aprox .250" + the valve seats... and re-core your casting so the ports would correspond...
And the pushrod holes...
And the cylinder spiggot holes Approx .250" per side
And the stud hole pattern.. Approx .250" per side
I'm not saying it can't be done, just won't be easy.
You would basically have to make a re-designed head, based on your casting... I would try to get a bunch sold before they were made.
I think it is still easier to move the stud holes in the case, and use one of the many good / Inexpensive designs available for the Type I (average application Thru 230 H.P. normally asperated).
Extreme Drag Racers will still need the Autocraft heads / Scat split ports....
You can modify certain aftermarket heads to run that big of bore / Type IV stud spacing... It's alot of work, But I do these $$$ / still way cheaper than producing a head.
Good Luck, Jake
Good Luck, Jake
pocketrocket
fastoldvwnologin
MASSIVE TYPE IV
pocketrocket
Jake . Yes with hours & hours of work you can do amost anything, but is it worth anything when you are done. You should have lots of other t-4 projects to do with out tring to adapt a t-4 head to a t-1 engine. Why dont you show us ALL one of your t-4 castings. I would like to see that!!! Thanks Rocky
MASSIVE TYPE IV
Casting is not done yet......
No where near it.
I was just trying to share the fact that the head could be made to work.
I guess you are right, the nmachine work to make the casting compatible with a T5 engine is less more than changing the bore spacing on a TI head for the job.
It was just something I noticed and thought I would share.
There will be zero pics of this head till it gets fully tested, molds are made and I can sell them.
Atleast a year.
No where near it.
Atleast a year.
- Wally
Jake,
Good thinking!
Since all the type 1 aftermarket heads don't cool well enough for street use and I know street engines are your main interest, I trust you that if you make one, it will cool well enough!
The same issues of performance and cooling (street) capacities exist for T1, T4 and T5...
In other words, there really should be a vast market....
Take care,
Walter
Good thinking!
Take care,
Walter
