Wide Fenders On a Thing
- Bob Ingman
After viewing Erics Thing I have to admit that I admire the look presented by the set of widened fenders.
I am going to guess that the rears are from the Thing Shop and the fronts are from So Cal Imports. Anyone out there in Thingland that can confirm or dispute that analysis? Keep on Thingin. Bob Ingman
- Kubelmann
I am on the wide fender search also. I have no interest in fiberglass. I have been collecting stock Thing fenders to make a clone fender by cutting one short and one long and meldingn the two. My rear 10x15 stick out way far. Where is Eric's car posted? Tell me more about the Thing shop and SoCal Fenders. K-mann
- Bob Ingman
KUbelmann Erics car is posted right here on the 181 Gallery thread.
So Cal Imports fenders are different from the usual wide fenders because they are high and wide both. Notice there is a three inch raise on them in addition to the width. Somewhere in a HVWs I have the story of their development. i can probably scan it to you if interested. Best of luck. Bob Ingman
- ericj8
Hi Bob,
My fronts are So Cal's "pre-runner" fiberglass fenders. They are actually 2.5" taller and 2.5" wider. The owner of So Cal has a Thing himself and has tested these fenders and he told me the tire never hits. I forgot what size his tire was. He is also using 3" raised spindles. I bought a set of those from him too but I have yet to install them because I might go with a different suspension front end.
As for the rear, my fenders came with the car. So Cal sells fiberglass fenders 3" wider.
http://www.socalautoparts.com/HotVWs_Ad ... d_p05.html
And The Thing shop sells 4 inch wider.
http://www.thethingshop.com/detail.asp?PRODUCT_ID=181WR
Then these are another kind of I have seen. For the rear, they are bolted to the car and not the original location.
http://www.thesamba.com/vw/classifieds/ ... p?id=49441
Hope this info helps Bob.
- Bob Ingman
- Bob Ingman
- Bob Ingman
- Bob Ingman
- Kubelmann
So I checked out the pictures of Eric's Thing and I must say it looks way cool. I like Bob am now thinking I could sell my Thing fender collection and do the 4" fiberglass rear fenders that body mount and perhaps could run my favorite rear tires (BFG A/T 31 11.5 x 15) without a body lift. As a result of my set up I was looking at the Mickey Thompson Baja Belted 29x 11.5 x15. But I actually designed my gear ratio around a 31" tire. I have rear centerlines 5x130 10x15 and front centerlines 5x130 7x15 From this thread I am imagining that I could run 7x15 front and The BFGs rear by selecting the correct fenders. I really liked the picture of the fenderless Thing that Eric posted. It makes me want to remove my fenders and build from there. I still prefer metal to fiberglass. I only wish that I had current access to the fab tools to knock out some fenders. Like most of us I have a long history with metal fabrication and have dabbled in fiberglass molding and by far prefer metal. How do the body mounted fender attach? After my current venture of installing thhe John Massengale beast into Herr K, I ma quickly becoming a fan of cutting the back bdy bar out of the way to make a turn key install possible. This big mama T-1 more than fills the slot. I am a long term sawzall fan...K-mann
- ericj8
I was wondering the same thing.How do the body mounted fender attach?
Yes that fenderless thing looked awesome. The owner told me he takes his Thing out to Glamis and several other off-roading places. He says his car does fine with stock engine and suspension but he can't always do the big dunes or it slows down with another person in the car.
I was thinking of maybe making the fenders easily removeable like with Dzus fasteners. When I installed my turn signal lights and headlights on my fiberglass fenders I added plugs if I ever do consider taking the fenders off for off the street use.
Mattt
I dont know what sort of 3" raised spindle can be used on a Thing. Please post a pic of the spindle you got from them. There is a 3" raised spindle for a Bug BJ front end, but not the Thing. Raising a Bug front end 3" with spindle makes it roughly equivalent to a Thing front end, other than the crappy ball joint arrangement. Bug bottom ball joints can pop out easier since they are upside down. Street,,,,no. Off road.....Yes.ericj8 wrote:Hi Bob,
Mattt
What do you have against the glass fenders? Puts your car on a diet, and they are fixable then. Im sure you know, you'll have to fabricate wider/taller steel fenders.Kubelmann wrote:I am on the wide fender search also. I have no interest in fiberglass. I have been collecting stock Thing fenders to make a clone fender by cutting one short and one long and meldingn the two. My rear 10x15 stick out way far. Where is Eric's car posted? Tell me more about the Thing shop and SoCal Fenders. K-mann
