hydrolic lifter adjust
dave menche
Post by dave menche »
I have a 86 Vanagon. It has low compression on one cylinder. I'd like to assure that the valves are closing correctly. How does one check/adjust the hydrolic lifter equiped valves.
thanks dave
To verify they are closing for your compression check, adjust ALL to .006 clearance just like doing a bug.
For the leakdown check, take the rockers OFF. (Jakes idea)
If the motor has sat around, it might have a little rust on the cylinder walls, and MAY get better as it runs.
The "right" way of preloading them depends on who you ask.
I check the radius on my screws, fix/replace as required, and give it 1/4 turn past contact, and then forget about it.
Some folks like to _leave_ a small clearance, as it assists in pumping the air out WHEN it gets in the lifters by providing a full stroke, at the minor inconvienence of bit more noise.
IIRC, the Bentley manual says something like 2.5 turns past contact, but I really can't remember at the moment, nor find my manual.
And how "low" is low? ARe they all close, or is one much different?
fatsback
Post by fatsback »
The original VAG repair manual says 2 full turns after contact to preload the lifters..
If they are trapped with air or they are bit worn. try to adjust 1/4 to 1/2 turn after contact.I adjusted my lifters today with the VAG method today with "ticking" noise as a result(2 full turns)...then i re-adjusted them with 1/2 turn and it was no noise from the lifters at all..
Check this link also:
http://www.bostonengine.com/articles/hydraulicll.htm
