Window Regulators
- DeathBus
Window Regulators
Any interchangability between other models? They dont look like any I have ever seen.
They look similar to some of the ones in the Audis..when you can find them manual roll-up. If need be though...you can drill out the rivets on the gear holder and steal a crank asembly from a type 3 and then use 3mm bolts to put it back together. Clean the heck out of the tube and spring assembly with berrymans...then pump it full of permatex super lube. It will never stick or fail again. Ray
