Gas Tank
- ecdez
Gas Tank
I did a search and didn't find anything so now I'll ask.
My gas tank need a good cleaning. Is there any reasonable way to do this with it in the car?
I'll be surprised if I get a positive response to that one.
So, on a scale of 1 - 10 (with 10 being the hardest) what would you rate gas tank removal at? The back of the car is still on ramps so I havn't even climbed under the front to check it out. Any tips? Anything not to do? This will be the last holdup to getting it back on the road so any help is appreciated.
67 T1
I've got to do the same on mine. I have no idea of the current condition, but a rusty tank on my 181 caused much pain,....and walking.
At that time, I was told to take the tank out, wash down (clean) some gravel, throw those in there with about a 1/2 gal of gas, and vigorously shake. I didn't do this, I just bought a new tank.
- ubercrap
http://www.prp-porstore.com/page/por15/ ... alers/FTRK
Suspension will probably have to come out of my cars anyway, man I can't wait! I just need a place to work...Company still hasn't decided if my department will move yet, so everything is on hold, damn.
Yup...suspension has to come out. But...the suspension is less than two hours work. Really easy. The tank will have issues though.
(1) put up on stands
(2) remove wheels
(3) Remove struts complete
(4) hang calipers with discs Knuckles and off to the side. Use heavy wire.
(5) Loosen clamp for steering column.
(6) remove 3 bolts from steering box in fenderwell
(7) remove 3 bolts from idler bracket in fender well
(8) get a jack or a prop for the suspension "T"
(9) leaving ontrol arms and ball joints attached....market exact location of T piece front and rear.
(10) Remove 3 19mm suspension bolts.....suspension falls on floor....or jack....done!
The tank is held in with a bolt at each corner. But...it has very hard to reah stiff breather tubes on the upper right...and small bore breather tubes too. Don't forget to disconnect the sending unit.
You should drain the tank completely. Disconnect the hoses. Hose it out. Let it dry for a day or two. Buy 2 gallons of muratic acid (swimming pool hydrochloric acid mixture...wall mart...about $6 a gallon or less). Carefully mix it with watre to make about a 70-30% acid to water mix...to pour in the tank. Fill it up, let it sit for about 5 hours. Slosh it around. It will fizz. It will literally eat every spec of rust. Drain the acid int a 5 gallon jug. Rinse the tank twice. Let it dry for a day. Yes... it will surafce rust on the inside. Thats what you want. get a gallon of OSPHO (phosphoric acid dip) at ace hardware. Pour in a quart, slosh it all around thoroughly. Let sit for a while ...repeat. Pour out the stuff. If its warm outside an the tank is in the sun....do this 3 times in a day. Then let it dry 24 hours...rinse with solvent (mineral spirits)...done! You have turned the now uniform surface rust left after the acid...into black oxide....permanently. It will not rust again. This is good for very lightly crusty tanks.
(2) remove wheels
vwbill
The Quick flush.
You could pull the drain plug and drain the extra gas then put a hose in the tank filler neck and flush with your solvent or cleaner of choice for the fast flush,lol! bill
- ecdez
