These are not mine but look exactly the same.
Hey now, I'll put my dual kads up against anything anyday, the throttle response is WAY better than a progressive and 2 times as good as fuel injection. Kads are just way finicky about what you use them on and how you use them. They dont have the prestiege of Webbers but I have properly tuned Kads and they run just as well as dual 40 webbers anyday!Gotoraygreenwood wrote:You didn't think I would really leave an answer like that did you?
Yes...those are central idleing. You cannot cap them, or the right hand carb will not idle and balance. I will consult the book...and drop in a note later.. My last use of a carburetor...was for a door stop.....A bag of them also makes a good boat anchor....hee hee. Actually they work quite well...a little finicky....but not as good as injection any day. Much Much better than a progressive or dual kads though
Duals are always better than a single progressive ANYDAY, take that hunk of poop and use it as a boat anchor, door stop or whatever DONT PUT IT ON YOUR CAR. There is a reason why they are cheap, they are cheap!ecdez wrote: I guess the question now would be, are the duals going to be that much better than the pregressive that I should spend about $25 on rebuild kits, a few hours rebuilding, and a few hours dailing them in? Whatever carb I use, it will probably be on there well into the winter.
Any opinions?
BTW: I got the engine in this weekend right before the hurrican moved in.Still need to hook everything up, but at least it up in there.
