head assembly...rocker stud oring/rubber gasket needed?
surfbug1
Post by surfbug1 »
the rocker stud, I heard it takes and oring.....
but in the haynes manual it shows a rubber gasket like what is on the oil coller....
why is this gasket/oring needed?
which one is it?
thanks
al
surfbug
CHAZAVW
Re: head assembly...rocker stud oring/rubber gasket needed?
Post by CHAZAVW »
surfbug1 wrote:the rocker stud, I heard it takes and oring.....
which one is it?
thanks
al
surfbug
on the rocker.... there is a black o-ring.....
on the oil cooler adapter there is red or green oil seal.....
turboblue
Post by turboblue »
If your rocker stud holes are a through hole, then yes you need them. Black O-rings about an 1/8" cross section, 1/2" or so on the OD. On some cylinder heads, these tapped holes are a blind hole. No O-ring necessary.
Gary
Turbo VW Sand Drag Buggy
2013 Polaris Ranger 4x4
My Website
Shop Facebook Page
Glenn
Post by Glenn »
All the gasket kits i've bought come with the o-rings.
Post by Marc »
Early (40HP-style) heads used a wedding-band-looking seal, late heads used either a thin O-ring or no seal. It's pretty obvious what's needed by looking at the depth of the recess around the stud; the no-seal type have a small chamfer but it isn't big enough for the O-ring to sit in.
surfbug1
Post by surfbug1 »
I will use the black orings that came with the kit.
they are as described by
"""Black O-rings about an 1/8" cross section, 1/2" or so on the OD."""
What actually do these o-rings do, and why are they required?
they look like they are just for vibration control.........of the rocker arm assembly.....right?
al
surfbug
turboblue
Post by turboblue »
I explained the reason for them in an earlier post. If you have through holes for your rocker stand studs, you need to use them. If you have blind holes you don't. I'm talking about where the actual rocker stand stud screws into the head. It either pokes out the back or it doesn't.
The o-ring keeps oil from wicking past the threads and causing a leak.
Gary
My Website
Shop Facebook Page
Xoloski
Post by Xoloski »
Do you have an actual size of the O-rings?
I know you said .125 cross section x .500 OD but have you actually measured the O-ring?
Also, I would think the O-ring would be metric, not SAE.
Not trying to pick a knit, but I don't want to buy a whole gasket set, just the O-rings and the nearest parts store where I will be going in Alaska is a considerable distance.
If one does not fail at times, then one has not challenged himself.
Ferdinand Porsche
Xoloski
Post by Xoloski »
The actual size of this o-ring is 2.5mm cross section diameter x 13mm OD.
The SAE approximation above was very close.
Ferdinand Porsche
