what does IDA, IDF, ICT stand for when talking about carbs?
vdubvr6
um, yeah, what the subject said!!
just wanna know differences and what not! thanks guys!!
VGM
Generally speaking here is a run down on the differences:
The letters are model designations followed by the throttle size in millimeters.
The Weber ICT 34 is a single throat dual.The Weber tuning book I have calls it a primitive design but they work well for smaller street engines unless your trying to pass an emissions test.
The Weber IDF comes 36,40,44&48mm.It is a very popular dual throat.It is used as a dual and often as a single carb(with different jetting).It is a great street/strip carb.
The Weber IDA 48 is a serious race model.It can be modified for the street and often is.It is also often modified into much larger throttle diameters for monster engines.
- sideshow
The Weber progressive is a "32/36 DFEV" or a closely-related variant. The "DG" family is a mirror-image cousin so you should be able to use a DF on one side and a DG on the other to simplify the linkage.
Claude's Buggies once sold a setup for dual progressives based upon a smaller series; I had a customer who put one on his baywindow bus 1600DP and loved it once we got the linkage sorted out, performance felt comparable to Kadrons to me. I've never seen a dual setup using DFEVs but unless there's some problem with float-level control when turned sideways the only reasons I can think not to use them would be space considerations in a bug engine compartment and possible transition problems (like getting the power fuel circuits in both carbs to work evenly). The problems usually encountered with single progressives are typical of any center-mounted carb...
- sideshow
I would like to revise my guess loosely based on the ?Weber Tech Manual By Bob Tomlinson Copyright CB performance 1998? http://cbperformance.com/catalog.asp?ProductID=4
ICT
Does C mean one barrel or used one per engine?
IDA
Weird the the 911S had OEM IDS, 911T had OEM IDT or IDTP, and the 914-6 had IDTP. So they were not all racing only models and more common in 3 barrels than 2.
D must NOT mean dual barrel, maybe D is used in pairs?
IDF were listed as used as OEM on Fiat, Ford, Lamborghini, Lancia, oddly no Alfa Romero OEM listings. The guess is that F is Fiat due to volume or used first, however that same argument could be made for Lamborghini. So F is Lamborghini?
So I didn't find a letter breakout codes and am more confused now more than ever.
ICT
I still think T is tractor, don't see any evidence however. It could mean ?minus the water choke or cold start device.?...variant of the Weber IRC series of carburetors that at one time were supplied to the Chrysler plant in France.
IDA
It sounded like the IDA prefix means racing only. The only OEM listings I saw were Porsche (904/911/914-6)....destined for use on water cooled Italian V6 and V8 racing engines.
also
Motori con Cilindra AV
Bruce2
The IDA was introduced in 1964. Prior to that, the IDM was used. An IDM is almost exactly the same as an IDA, but a little more crude. I have seen references to use of the IDM back to 1957. One famous use of the IDM was on Masaratis. Thus the M is for Masarati. My guess is that when they redesigned it, they were using them on so many other cars (Porsche, AC Cobra, Masarati) that they gave it a neutral application letter "A"sideshow wrote:
D means double choke, definitely. IDAs were used in pairs and sets of 4 and 6. The number of carburators on one engine has no effect on its type designation. There have been some cars that only got one IDF.sideshow wrote: D must NOT mean dual barrel, maybe D is used in pairs?
Lamborghini gets the letter L, as in DCNL. This is the Lambo version of a DCNF. If an existing carb works perfectly on a new application, they don't change the letter. IDFs have been installed on Lamborghinis. The DCNL is a radically reworked carb, specifically designed for Lamborghini.sideshow wrote:IDF were listed as used as OEM on Fiat, Ford, Lamborghini, Lancia, oddly no Alfa Romero OEM listings. The guess is that F is Fiat due to volume or used first, however that same argument could be made for Lamborghini. So F is Lamborghini?
Slow 1200
- sideshow
That kills me every time I read that.Bruce2 wrote:Its been my observation that a 2bbl progressive carb is only good for increasing fuel consumption. Two of them would be a disaster.
I have taken a close look at a 914-6 induction system, despite going to public schools I can say that there are 2 carbs, and 3 barrels each.
EDIT: 3C/1 they do like they are retro fitted to add another barrel rather that designed that way from scratch.
D might be port on port? Just throwing out more theorys.
The book implies that Lamborghini was first with the IDF but I agree that Fiat make many more cars and If I was Weber I would make first for Fiat, then for the low volume builders.
- VIPERGREEN76
Re: what does IDA, IDF, ICT stand for when talking about carbs?
To me, IDF means.
I=individual
D=dual
F=fuel
I=individual
D=dual
F=fuel
76 SEDAN
EC type 4 Conversion project
