Drilling head studs!
Jim Andritsakos
Post by Jim Andritsakos »
Hello all!
I would like to ask what is the correct procedure to drill a wbx head stud ?
I like to know which is the biggest size of the drill bit that is required to be used ? If I am correct the head studs are 12x1.75 ?I want to clarify if you drill them with a slightly oversized drill bit and the helicoil them ?
Thank you all guys!
With rgds,
Jim Andritsakos
1973 1303 German look (project)
1975 ex Bundeswehr vw 181 (FS)
1988 T3 Syncro 16 doubledoor
1990 T3 Syncro panel
1985 T3 Syncro ambulance (FS)
1985 T3 2WD panel (FS)
pocketrocket
Post by pocketrocket »
Hi Jim You are repairing the stud hole in a case with the water jackets on right. Is the stud broken off? If so I use a 3/8 carbide end mill in a long holder I made to core out the old stud then soak with kroil & use a easy out with heat to remove the cored stud. The boxer head stud at the case is a 12mm x1.50 thread. I use a very long .484 drill & I use a Timesert 14mm x 1.50 od with a length of .950 or 24mm. I made a long but thin tap holder to hold the tap in my milling machine to do the job. Hope this helps. Rocky
Guest
Post by Guest »
Hello Rocky!
Thank you for the detailed anwer.
Problem solved!
Rgds,
Jim Andritsakos
Ah! Forgot to log-on all the time!
Thanks very much for the help Rocky.
Now I want you opinion to properly repair the front engine mount in a engine case (LH side) as it was damaged and poorly repaired.The hole is off centre and enlongated also a small cap in the bottom (I think it seals the oil pressure valve ?) is come loose!
I want to make a faultless repair!
Thanks again!
Jim Andritsakos
pocketrocket
Jim, on the repair of the L-H side mount hole. How big is the hole now? If it is less than .468 15/32. I would bolt halfs together remove bottom 2 studs flywheel end set it flat on milling machine. Use the old mount as my template bolt the R-H 2 bolts loose and try to line up on the outside the L-H side boss from the case to the mount, Tighten the R-H bolts. Holes in the mount are about .425 or 27/64 bring drill to the center. Remove the drill & the mount plate, find a end mill to machine hole to get it centered then use 15/32 drill. Go down only about .900 or less DONT DRILL TO DEEP keep checking the bottom of the hole this is the outside of the pressure releif valve. Then I use a 14 x 2.0mm x 10mm steel insert. If the hole is very oversize I end mill & Drill to 37/64 .578 & I use a special insert that is 5/8 x 18 x 10mm . I have repaired a number of cases both ways worked great. Good luck Rocky
