Vanagon timing mark?
citylimon
Does the timing mark on my 84 vanagon denote TDC or where the timing shoud be set at idle?
Jim Andritsakos
Engine code GW correct ?
It is ten degrees +/1 one degree at 880 +/- 50rpm.
If 95 octane fuel is used is five degrees +/1 degree at 880 +/- 50 rpm.
PLEASE SET vacuum hose DIS-connected.
Good luck
Good luck
Jim Andritsakos
1973 1303 German look (project)
1975 ex Bundeswehr vw 181 (FS)
1988 T3 Syncro 16 doubledoor
1990 T3 Syncro panel
1985 T3 Syncro ambulance (FS)
1985 T3 2WD panel (FS)
