Hello Rocky,
As you have a very good experience in gearboxes also I would like your help.
I remove a ZF LSD from a 1978 single side cover trans and I would like to put it in my 1975 single side cover trans (both are 181s).
Is it required to heat the ring to install it ?
How much torque is needed to the ring bolts ?
Also how much in the side conver bolts ?
Diff has two clips (one of each side I have to use the one that came with lsd or from my box ?
I am apologize for all these questions !
Thank you,
To Rocky Jennings (off topic)
Jim Andritsakos
Jim Andritsakos
1973 1303 German look (project)
1975 ex Bundeswehr vw 181 (FS)
1988 T3 Syncro 16 doubledoor
1990 T3 Syncro panel
1985 T3 Syncro ambulance (FS)
1985 T3 2WD panel (FS)
pocketrocket
Jim do you have a without guesswork book? It was a factory book given to all the mechanics at the dealerships back in the 70s it has a lot of info. in it . If not I will look it up on monday. I heat my ring gears. 45 lbs on most ring gear bolts. 15lbs on thr side covers. not sure about the clips. Rocky
