Shimmy 1973 Thing
captken
Shimmy 1973 Thing
Hello, I have a 73 Thing with 60,000 miles. I have replaced tie rods, damper, and had the front end aligned, new tires. I still have a shimmy. It got better after all of that but still exist. the car is totally stock. It happens about 40mph and above. Anyone have any suggestions???
At that mileage I wouldn't expect there to be any problem with the balljoints or control arm bushings/bearings. Gut feeling is it has to be in the tires. I assume the new tires were spin-balanced. Once in a while a radial or bias-belted tire gets built with a skewed belt - it can't be detected except by X-ray, but the tire tries to track with it which makes it take a squiggly path down the road. Have you already tried swapping the tires F<->R or borrowing some known-good ones?
MASSIVETYPEI
- Kubelmann
Sorry Guys, In this case you are all wrong. I would bet good money that this is caused by a bent wheel. Been there done that. Rotate tires front to back and if the wobble goes away, you have your issue. The speed at which it occurs is a dead give away. I just went through this issue on a car last Fall. You can jack up one tire at a tim adn do a run out test to find a bent wheel.. K-mann
